LazerBeakShiek
It is a life preserver
A home recordist will need to level/limit their tracks before they can mix them. That is going to require a variety of parameter changes. I was trying to find a capable machine for the beginner.
Explain? You are compressing it 4x...really?if you're mixing anything bigger than a duo, you'll probably want more than four channels of compression, so it starts making sense to trade doing everything for some variety.
You saying the Aphex is useless on it’s own?Put it in front of your compressor. You'll hear it.
Usually I have it last on my stereo buss. It just seems to tighten things up a little.You saying the Aphex is useless on it’s own?
no. turn the drive knob for max reduction. You can hear what it is doing.You saying the Aphex is useless on it’s own?
To be honest I haven’t figured it out yet.When you do compression. I like to start at the extremes and dial it back. You need to hear what it's potentially able to do.
A fixed release compressor...would be the EXACT SAME as a distortion pedal with one setting of distortion...Thats release.
Put the compellor as first compressor. Generally the slow, gentle one is first, and then a fast compressor is second. Fast and infinity to limit.
No, I mean a channel of compression for each track. So for a duo with two vocals and two instruments, that's four channels of compression. That's assuming you're mixing in analog. On my old 16-channel live mixing rig, I had 16 channels of compression.Explain? You are compressing it 4x...really?
I was thinking like 2-5:1 ratio subtle , then spankin it to infinity with a second.
Oh.. Well, I used some examples showing how some professionals are using these products in modern music.No, I mean a channel of compression for each track. So for a duo with two vocals and two instruments, that's four channels of compression.
So, its easy to see why you would want independent attack and release knobs..Placing a compressor in front of a compressor multiplies the ratios, not additive. Stretchy effects become possible with attack / release combinations... It is like placing a magnifying glass over a magnifying glass.If you're using the compressor on the input of a DAW, the last thing you want to do is over-process audio before you have a well developed mix for context. Using a fast attack can take the life out of a track if it's not a good match for the material.
Before it was "Having only one compressor means it's best to have wide attack adjustment," and now it's "Having multiple compressors means it's best to have wide attack adjustment." So I'm not sure what your reasoning is for not wanting a compressor that can't go to 1 ms attack, especially when you have someone here who can tell you that the original Pro VLA is a very useful and good sounding compressor.So, its easy to see why you would want independent attack and release knobs..Placing a compressor in front of a compressor multiplies the ratios, not additive. Stretchy effects become possible with attack / release combinations... It is like placing a magnifying glass over a magnifying glass.
I see a definite benefit to a sweepable knob.2 ms, so even that covers almost all situations where you need a fast attack.
Right. Yeah tracking I put nothing...A limiter perhaps so I dont need to look at it.These days my use of hardware compressors is strictly for tracking as I'm looking for minimalist processing. The rest can be handled in post.
In the 70's I was recording on a 4 track. You learn to make commitments. Same with running sound for open mic. You need to have an idea in your head where your mix is headed because they are just going to plug in and go. I'm dialing in while the performer is bantering with the audience and tuning their instrument. A 7-8 piece ensemble will certainly keep you on your toes. Had the proverbial kitchen sink tossed at me and it was a great teacher.Right. Yeah tracking I put nothing...A limiter perhaps so I dont need to look at it.
Once I got it recorded, Im going to mess with. Thats the fun of finding the best bits in the wave, and pushing it up loud.
