looing for a portable studio around 500$ maybe dpo1-fx by tascom
  • Thread starter Thread starter robfurman
R
robfurman
I am trying to go0 portabloe with my studio work..really i need something that only really needs one or two tracks..i AM recording only choirs, concert bands, speechs..things like that..
anyways I foudnm one that looks cool but i was wondering idf someone with more experience than me can look at the specs ansd tell me if it is good for me or not...it is the tascom dp-01fx portastation...
let me know what the experts thinkj
thanks all
rob
Wello, it's a brand newo u0nit, just intro0duced a few0 weeks ago0. I do0n't thinko there's much of a user-base0 out there0.
As far as the DP-01FX goes, it seems comparable to lots of 8-trackers out there. The 2-track simultaneous recording is something that more experienced users would find limiting, but it depends on the scope of your production needs.
F/I, if recording only two tracks of a chorus is satisfactory, wouldn't recording 4 or 6 tracks of same chorus be more versatile and fulfilling as a recordist? That's a personal judgment each of us needs to make. Further, the DP-01 and /FX will record only two discrete inputs, direct, making the 8x2 mixer section useless on the recording-side of the equation. In fact, it only has 2 inputs, total, which is a severely limiting factor.
Also, on the DP-01FX, the "EQ" section on the 8 channels looks like it's dedicated to playback only, (although I've not thoroughly checked the manual on that). Being Hi/Low EQ and playback-only EQ would be a feature that more experienced recordists would also find limiting. (Not 100% sure on that, but I have checked the manual with a lite reading, as of this writing).
Fact is, if you're only recording 2-tracks simultaneously, and in total, where 2-tracks is your entire production, then an 8-tracker might be overkill-tech for your needs.
Honesly, based on what I've determined about the Tascam DP-01 and DP-01FX, I'd still stick with the trusty and proven brand new Tascam 424mkIII, which has a full functioned 6x2 front end mixer, ... that you may employ to mix the signals BEFORE the recording stage,... either from 6x2 & record 2-simultaneously, OR in 4-DIRECT mode, in which the 424mkIII will record 4-tracks simultaneously,... which STILL is a BIG advantage in tech-terms over the DP-01FX. The EQ section on the 424mkIII is a slight cut above the EQ on the DP-01FX, and it may be used in record-mode AND playback-mode.
The 424mkIII retails brand new for $329, which is a feature/price package that's still hard to beat, even in this digital-gotta-have-it age.
IF, by chance you're hung up on the fact it "must" be digital,... then the Fostex FD8 is a bit more versatile and feature loaded than the DP-01/FX. Although the FD8 is an Ebay item now, it's still worth looking into further, IMO.
This is probably not the critique, review or advice that you were looking for, but it's my honest opinion, and with all things like this, YMMV. :eek:
PS: Find the downloadable manual for the DP-01/FX on the official Tascam website. A thorough manual reading would probably settle pretty quickly if the DP-01/FX is right for your needs. I know it's not right for mine. YMMV.
After some futile Googling, I think you probably mean the Tascam DAP1 Portable DAT recorder.
Get it only if you want to enter the world of fussy little tapes and fragile machines. DAT was a format that I am all too familiar with, having struggled thru it's infancy and brief adolescence. I rejoiced when recordable CD's hit the human-price level and snuffed DAT out in it's tracks.
In my humble opinion, it would be a bad choice in the long run.
Nah, sorry!
I was mocking the typ0's in the previous post, but...
In plain English,...
Tascam has just announced/released the brand new DP-01 and DP-01FX,... two little hard disc Portastudio format recorders that record up to 8-tracks, total, 2-tracks simultaneously, and has a "mixer board" interface for outgoing/playback EQ and effects sends.
See the DP-01 and DP-01FX at the official Tascam website. These products were literally just introduced only a few weeks ago. I doubt if retail outlets have them yet, or are just getting their first few shipments. The D/L version of the manual is free, and will answer many questions you have about it. Even though it has a "mixer board" interface, it's still a largely menu-driven-type of box. Not right for me, but YMMV.
Thanx0. :eek:
thanks for the opinion..but...
I understand everything you were saying..but I am a novice..so what in your opinion would be a better machine to get for me..the reason I said 2 tracks is because I dont know any better and i want to have one sterieo track that i can put into the computer where I have my real software to edit..etc..any sugesstions
rob
The FosTex MR8 may be an option. This is an 8 track unit that can record up to 2 tracks at a time. It is memory based and retails for about $300. I have one and they work well.
Ed
Sure,... sorry if I was blabbering, or seeming to take things for granted.
In order to make the best choice in recording equipment, understanding your own recording needs is essential. That isn't necessarily something I have a crystal ball on. I answer questions based on my understanding and reading of the questions. My answers are as straight as possible & based on analysis.
Based on what you stated, (I'll assume, if I may), you want your end result to be in a standard CD audio format, in stereo. However, what goes in behind the production of a stereo recording may be a bit more complex, in a lot of cases, the closer you look. And, so logically, the gear gets more complex as you go up in production value.
The level of technical capability you need in a recording platform to really do it 'right', might be a bit more complex than on first glance. You have to carefully consider what you want to record, and how you want to record it, and/or what final production value you're shooting for.
For basic starters, you don't need much in the way of specialized equipment, if you just want to record 2-tracks onto your 'puter. Buy a mic, a small mixer, and record to your 'puter with recording software, in basic stereo or multi-track, it's your choice. Software does it all, right in the box. With a multi input soundcard, you can record lots of tracks simultaneously. Lots of people do their recording on a 'puter, and swear by it. Desktop computer recording rigs are great for fixed installations, but can lack ease of portability.
Another alternative would be a laptop and a USB audio interface, again, recording on the puter directly, using software. The USB audio interfaces are more limited on the simultaneous number of channels they can handle. However, laptop/portable sound device is a choice that many people take, in home recording. Portability is a big plus.
Then, you get into the standalone portable recording workstations, including the brand new Tascam DP-01/FX, and all the similar devices in that class. They are many and varied, and in the quick analysis, Tascam seems to have a very nice unit in the DP-01/FX. It's pretty much a leading value, right now in it's class of brand new porta-format HDD 8-trackers. The DP-01/FX' 8-tracks could boost your production value over standard stereo.
However, the DP-01/FX has glaring deficiencies, in that it only records 2-tracks simultaneously, has only 2 inputs, has minimal or non-existant front-end mixing, and has cheesy EQ. However, all the units in the class of the DP-01/FX are roughly the same, and the 2-input/2-simul-max recording limitation is not a problem for some users. It's fine for recording by yourself, but is probably not as good for a choir -type thing.
For someone who may want more control, and a higher production value, plus more versatility in general, the (cassette 4-track) 424mkIII should be checked out, too. That's based on the features of the DP-01 vs. the 424mkIII.
(F/I) With the DP-01, you could record 2-tracks simultaneously, live, and that's it. 2-mics and 2-tracks, and kabam, the live recording's done. With (f/i) the 424mkIII, you could mic the same choir with 6 mics, and send the audio to 4-tracks simultaneously, which would be a more highly produced live recording. The more tracks you have recording simultaneously, and the more inputs you can bring to bear at once, the more highly produced your recording can be,... in a one-shot live recording circumstance.
I'm just trying to put the machines and technologies in perspective, and giving examples. Your question was about the DP-01/FX, an recording a choir. Sorry to get all basic on'ya.
The DP-01/FX is a fine unit in it's class of recorders, probably best-in-value, but it pales a bit as compared to a whole host of other recording technology/platforms. ...
Here's what I'd do to record a choir, live in simple stereo, for producing a cd.
I'd use a one-point stereo mic, with L/R mics plugged into a capable vintage stereo cassette deck with mic inputs, (such as Technics or TEAC), and record to tape. Or, better yet, mics into a 2-track r/r recorder running 15ips/halftrack, (such as Tascam 32 or 22-2, Fostex A-2 or Model 20). Then, I'd dub it over to the puter in stereo, and badabing, produce a CD.
If I wanted to record a choir in a complex mixing arrangement, I'd buy the Tascam 424mkIII Portastudio, and record the choir with 6 mics onto 4-tracks, and then mix down to the puter, for cd.
If I really wanted to boost my production value, I'd then get a Tascam 388, the ultimate king of Portastudios, and record 8 mics onto 8-tracks, simultaneously.
If I wanted to go more even hifi than that, I'd hop up to the Tascam 38 (1/2") and external mixer.
Somehow, the DP-01/FX doesn't figure into any of that, considering my own real production needs.
However, if I wanted a brand new 8-tracker, that has 2-inputs and records 2-simultaneous tracks/max to HDD, I'd consider buying the DP-01/FX, because it's pretty outstanding value in it's class. As an entry level device, it's not too shabby. It has some limitations, but can do certain things well.
I'll stop now.
