Steenamaroo
Hello folks..
Not often I'm in here..Hope you're all well!
I've acquired a little WEM Watkins copicat mkIV. It's the later solid-state copicat tape echo.
It's all looking and sounding good. I've cleaned the heads and path with 99% and all moving parts seems clean and free too.
However, every time the splice goes over the capstan I see and, more importantly, hear a little wobble in the tape.
At first I assumed it was just less than suitable tape weight or a bad splice but I have since bought proper pre-made loops for the machine and am having the same issue.
Ok, I'm going to fail at describing this but the wobble appears to be at the edge of the tape closest to the machine.
By that I mean it's an uneven wobble.
Where do you start with something like this?
I've tried three or four of the premade loops. They are the proper type self lubricating tape and the splices all look perfect.
Putting a little bit of extra pressure on the tension arm doesn't help so I don't think it's a tension issue there.
Is it possible for the motor to be weak? I can halt the capstan by grabbing it with index finger and thumb, but it's not a pushover.
Unfortunately I have no point of reference, so I don't know if that's normal or not.
Any help at all is much appreciated, chaps!
