jjones1700
Learning, always learning
I guess nobody has a minidisc recorder except for me??
Just had to put a post in this dead forum.
I'm proud of you!I use 2, sometimes 3.
Yep, sometimes these...I'm proud of you!
Sometimes, this...
MDM X4 MkII. Its ok, but I mostly use The B3. Sounds much better. Heavy, though.
I just use a Presonus Bluetube dual pre and a couple of mics. I use it to record practices.I take it you just run your sources to the B3 vs using the X4 then, correct?
I got may data disc from B&H Photo/video. The MkII will use regular disc, but will only use two tracks.I just did some reading on the 564.............have to use "data" MD instead of the typical audio ones right? How hard are they to find?
Does the Sony version use the "data" MD as well?
I might be looking into one of those two for my "mobile" studio of sorts. I'll leave the 424 all hooked up at the house.
